power window "clunk"
knuk
power window \"clunk\"
When I roll my window down I hear a "clunk" right before it is fully rolled down....sounds like something is about to snap. Any ideas on what is causing this?
622r109
liny
Re: power window \"clunk\"
sounds like the window track is going bad
Andrew/USPWR
W. Palm Beach
I think I had that issue with my SRT/10's window modulator. About $1,000 from Dodge so have done quick under warranty. Just make sure the up, and tilt position are right on the window, before they put the door back together and send you off. Air and water leaks will not be pleasing.
HARDVIPER
Temecula Ca.
Had simalar problems with my truck. I tightened up the bolts in the door panel and that fixed the problem
