Dan Aseere
97 B/W GTS, 7000mi. Power window drivers side goes half way up and stops, if I lower it back down and then up it goes all the way closed. Took off the door panel and lubricated as many spots as I could get to and also lubed around the seals and no change. Took out the switch and cleaned up the contact points and still no change. Any ideas? Thanks in advance.
