1996 GTS power window
VIIPER3
Quebec Ca
1996 GTS power window, no power at the switches. What fuse and relay controls the PW
GTSnake
Motor City
Check the wiring through the door grommets first. I pulled my hair out trying to diagnose door/window electrical issues and it turned out to be the wiring harness. I've since soldered 10 wires.
haneifk
Yea what he said. When mine went out it was broken wires in the door/dash area
Barry
Kill Devil Hills, NC USA
I had the same issue with my doors. It was broken wires in the door conduit. This is a common problem with these cars. Thankfully it's an easy fix. I also had an issue with the window not going down. That turned out to be a lose guide. All I had to do was realign it and tighten the bolt. Good luck.
