Hi
I have a little question about bigger throttle bodies for you.
I have a '94 RT/10, just installed the K&N Performance Air Box, opened up the Throttle bodies to 63.5 mm, and the same to the Intake Manifold. Now stragely enough, the car is suddenly not so aggressive anymore, it seems that it has lost some torque in the lower RPM's. My question is, do I have to recalibrate the computer ? Does my model have a 'mass air meter' or a 'manifold absolute pressure sensor' ? Because if I understud it right and I have a 'mass air meter', then there is another problem, because the computer should realize that it gets more air, right ?
Friends of mine said that I should change the headers too now. Others said that it's a good idea to change the headers because I did some modification at the beginning of the chain, but this is not an absolute must.
Now I'm confused, what should I do and where could I suddenly have my problem ?
I would really appreciate, if someone could give me a hint.
A mass air flow meter (or MAS) is a device that measures the amount of incomind air via a tiny heated wire in the center. A viper does not have a MAS, rather it relies on a Manifold Absulute Pressure sensor (MAP).
Now, with that in mind, lets move to the larger throttle body question. Going with a larger throttle body (either by Gen2 swap or porting) will not gain any HP, while most of the time it actually decreases power. On most cars, the throttle body is one of the mods done after a large amount of engine work...gains are nill with just a throttle body swap on almost any vehicle.
Re-callibrating the computer consists of disconnecting the battery for about an hour, and hooking it back up. This will cause the computer to "re-learn" your driving habbits and such, but will NOT affect the lack of low-end torque caused by adding the throttle bodies.
Headers are a good start to making power, but putting on headers while leaving the stock 2.5" (2.25 in some areas of the pipe) is not going to be worth the hassle. Everything on a car should be done in ballance, matching components will always yeild the larger gain. If you have the money for headers, I suggest you pick up a 3" exhaust system w/ hi-flow cats (or no cats) to a dynomax bullit muffler. You have side-pipes, so you might want to just have a exhaust shop fab up a 3" setup for you. The result will be an engine that not only can inhale a good bit of air, but can also expell it without much effort.
If you haven't already, go ahead and do the re-sync of the throttle cables. This can make a world of difference in throttle response! The article on this is located in the tech section, but feel free to email me if you have questions on it.
The real restriction in the intake system is the plenum itself.. but that's a totally different thread
MM
