Dave's Big Brakes
This is for those that want the bigger ABS m/c, along with being able to FULLY adjust the rear brakes(will work really great with TOM's 40mm rear upgrade). This allows either min or max brake pressure to the rears, to make them work even better. Playing with the dist block(removing spring,seal, or whatever) still doesn't give you full control. This setup will,from min to max press.
It will be available with a new ABS M/C, or use your old m/c. It will come with s/s lines, pro valve, a new dist block, and mounting plate(not shown in the following pic's), and will bolt up in the same position as the old hardware.
some pic's
These parts will be listed under New Products and Suppliers Specials, ck there for pricing, and info.
some pic's
