deadman
I installed mine (headers, hiflow cats, exhaust) on 05 vert and have some questions:
1. Hot hot hot - before I had stock headers wrapped in thermo wrap, stock cats and exhaust (no xover). I thought - based on the group wisdom on this forum - that primary cats are THE heat source in the footwell and removing them would cool everything down. With Belanger I get even more heat in the footwell. Will this go away with more miles? Anyone wrapped - shielded - headers and exhaust pipe up to the cats? (mine have only 50 miles on them, I know breaking in is like 500 and I know Lou is disapproving wrap).
2. Sound - AWESOME BUT - around 1500 RPM cruising there is a drone. At 2000RPM cruising the sound is almost whisper quiet (frequency being higher the drone disappears). It looks like 1400-1600 RPM is a sweet spot for the drone, unfortunately that's my 6th gear cruising rpm with 3.55s. @1200RPM and under no drone. Did anyone experiment with some noise -drone - canceling? (I had Corsa track before, in 2005, I think less drone but much much louder, I was too tired from it, so no I don't want to try Corsa - not starting a war here, sound judgement is always very person specific)
Other then that the whole setup is great. Fit and finish is
, Lou did really good job. I had Mopar street exhaust previously and the tips didn't fit, with Belanger not a glitch. Also the instructions are simple and if you follow them without cutting corners anyone can install these in a day. Sound at WOT is just overwhelming AND the car really got some extra ponnies (no numbers yet). I'd say if your neighbors allow go for it
