cyaford
Ever since I bought my Viper over 2 years ago, I've had a problem with 6th gear. Seems the synchro is going out. I have to engage the clutch for several seconds when going into 6th, or it will grind. I know, what the hell am I doing using 6th gear?
2nd gear will sometimes grind, but only when shifting fast.
I've never had the car to the track, but would like to make a few passes before the dragstrip closes for the winter. Obviously, I want to adress the transmission and get it working properly.
I have contacted 2 reputable T56 repair companies and below are their recommendations.
www.thegearbox.org recommended the following:
-Basic Overhaul kit($178), which includes:
1st & 2nd three piece synchronizer rings
3rd, 4th, 5th and 6th carbon kevlar synchronizer rings
brass reverse synchronizer ring
front and rear seals
shift fork pads
synchronizer keys
retaining springs
shifter bushing
-Billet 3-4 synchro keys $60(he says the stock ones have a high failure rate)
-4 sets of bronze fork pads $106 for 4 sets
Here is what Six Speeds, Inc. (formerly t56rebuilds) recommended:
-Blocker Ring Kit- $169 -part of the synchro that will need to be replaced if it is worn out.
-5/6 Slider Assembly- $95 - part of synchro
-5th Gear- $95 -replace due to damage from prolonged grinding.
-6th Gear- $95 -see above
They also suggested doing the following upgrades to give me a better and more reliable transmission:
-New 1/2 Slider- $115
-New 3/4 Slider- $115
-Billet 3/4 Keys- $75
-Bronze 1-4 fork pads- $60
-Steel 3/4 Fork- $39 (Vipers before 2003 don't have the fork)
-New Input Shaft Seal- $10
-New Output Shaft Seal- $17
Does anyone with experience see anything that is not needed or know of something I should add? I've been told to definitely do the 3/4 steel fork, since I'll have the transmission out. I plan to order the parts soon. Any suggestions or smart ass comments welcome.
shift fork pads
synchronizer keys
retaining springs
shifter bushing
