Question for the racers!!!
ACRGTS
How critical is a differential cooler for the rear end if you are plan to open track. Not competitive just wanna have some fun. I know it was critical with my 2000 Cobra R
Vic
Not critical unless you get really fast, and go a lot.
For starters, its better install some brake ducts, Brakeman 3s, Dot4 brake fluid, you already got the ACR oil filter adapter, need windage tray, trap doors, 20-50 Mobil 1, Water Wetter, RedLine p.s. fluid, tighten your p.s. resevoir cap every session, 5or6 points, later you might want to get a more agressive alignment, lowering a bit, Accusump, Hoosiers, big brakes, diff cooler, Penske tripples, roll bar, big radiator, well the list goes on and on!
A
ACRGTS
I am just going a couple times ayear with this car. I do serious tracking with a 2000 R that is all set up.
Ideal983
