I just reprogram the remote that I got from ebay. It is very good day today and I can't pass up to prep the car. Thanks to Tony and from the tip that I got on this site. It is really very easy if only I re-read the instructions. What I did is removed the quick connect from the EEM then ground the green terminal. Did not worked. Then leave all the keys on the center console and close the door to read the instructions again. My mistakes. Keys got lock and there is no other way to open the trunk. End up calling AAA and chrysler road side assistance for the key code. Pick up the key with the locksmith and finally I was able to open the trunk and open the manual release lock on the door. And finally I had the ssssnake woke up from hibernation.
Tony, Is it possible to put another hint on the thread on how to reprogram the remote? Meaning make sure open all your windows before proceeding just in case you lock your keys inside.
And does not need to disconnect the EEM from the quick connect. Need to have 18-22 gauge wire to ground the C-13 (green wire).
