Is it a simple unscrew to take off, screw on to put back on or is it more involved? I am planning on purchasing a 93 with fender mount antenna but storing it on a lift with the antenna attached won't be possible. Is it easy on easy off?
You do know the antenna goes down when
you turn off the radio?
Skeeter
Skeeter
NOT- the 92 & 92.5 Vipers have a one piece solid antenna!
Welcome to the "Carry-Over Club" - my '93 was the 34th produced. I put my antenna on finger tight so it is easy to remove when I put the cover on.
Skeeter
how do you know you have the 34th produced? and how many 92.5 vipers the
Check the last # on your vin.
Thats not the way to determine - as far as I know, the only Viper run produced in VIN order was the '98 GT-2 run of 100. If the claim of 34th produced is based on VIN number, it is just as likely incorrect. While it could be correct, knowing that it is so is a bit difficult, as the build order was not recorded (and still isn't) - VINs are assigned before production, then similar colors and trims are produced at the same time (which doesn't correspond to VINs). You might be able to reproduce build order from shipping manifests, etc, but thats unlikely.Check the last # on your vin.how do you know you have the 34th produced?my '93 was the 34th produced.
I'm not sure how math is going to help determine build order, when its largely unrelated to VIN. Please correct me if I'm wrong, but, as I understand it, it was just as likely that they built VIN 200 before VIN 100.<< how do you know you have the 34th produced? >>
this may help. a little math should get anyone pretty close.
'92 / 285 units / first vin - NV100001 / last vin - NV100285
'93 / 1043 units / first vin - PV200001 / last vin - PV201055
'94 / 3083 units / first vin - RV100001 / last vin - RV103087
'95 / 1577 units / first vin - SV200001 / last vin -SV201584
