1994 RT/10 Idler Pulley fail
phipplet
Friendswood, TX
My Idler Pulley on my 1994 RT/10 decided to explode! My Viper has 55k miles. I took the hood off for easier repairs. Replaced the alternator while I was at it. I had a hard time locating the Idler Pulley bolt and washer. I eventually located one on eBay for a 1994 Dodge Ram (Same setup). Going to replace with new serpentine belt, plugs, wires. Anything else I should replace while the hood is off. The air filters are new.
My tensioner gave up the ghost recently. Thank God it was right up the road from my house, and held together until I was home. Couldn't hurt do the radiator hoses while you have the easy access.
phipplet
phipplet
Friendswood, TX
While I’m repairing stuff, does anyone repop these?
@phipplet yes on fb but i think you can cut your our from mud flaps or something like that. There was a post on that somewhere just don't know where I saw it sorry.
white out
The Mitten
Mine failed too, just not as extravagant of a failure, but left me on the side of the road.
If you have not already replaced your PS pump pulley, now is a good time.
The OE bracket is die cast magnesium. As long as the attachment bolts to the heads, and to the steering pump are torqued properly, the OE brackets are lighter and fully up to the task. Your choice.
