Gen2 Hydraulic Clutch Line
jcgreywolf
NC
Im looking for a replacement hydraulic clutch line for my 99 RT/10. I replaced the slave cylinder with the LUK LSC134 and I CANNOT get the red dry break connector to seat into the new slave. I suspect that its damaged since it leaks fluid while disconnected anyways. If you push the clutch pedal in fluid will fly out of it freely.
After trying everything for 4-5 hours I gave up before I ended up breaking something. I removed the master cylinder today to replace it also so now I just need a new line. I see that the later gen 2s have a blue colored dry break connector and have been wondered if that will fit better since this one will not seat.
Also gonna see if maybe HEL can make a clutch line for me. Anyone know off hand the length hydraulic clutch line I need?
I just measured a takeoff clutch master cylinder hydraulic line at 33.5 inches connector to connector...from a friend's 01 R/T 10. I hope that this helps.
You might want to contact Tom Sessions in Hampstead, NC as he has a couple of new OEM masters (with hose). He also has had (and solved) what sounds like the same connector issue as you described.
He can be reached at910 228 8477
Dan Cragin
LA, CA
I believe I have a good used one if you want to PM me
J
jcgreywolf
NC
I ended up buying a whole new master cylinder kit for $250. Thankfully Mopar has used the same length and style connections for the gen 2, 3 and 4s hydraulic clutch lines. Latest Mopar# 4642666AH.
After taking the stock line out, that I knew was bad. I tried to see if pushing in the white plastic piece inside the dry break connector could close and it just went in even further and seized up.
I tested the new hydraulic line with the new LUK slave cylinder i bought and it snapped right in easily and to make it even better the release sleeve on this new connector has a ridge on it making it drastically easier to push in to release, Especially if you have the tool.
