-TRQuixote-
Having one installed this week and curious if the stock handle will work (preferred).
Thanks!
Thanks!
Yes the stock handle will work. Installed a few of the B&M Shifters.Having one installed this week and curious if the stock handle will work (preferred).
Thanks!
Does that work in conjunction with the B&M? It goes in tomorrow, so Id likely have to add that on myself later if so.Get an IPSCO lowering rod, personally for a '97 the 2" lowering is ideal.
Yeah, it replaces the stock shifter rod that threads into the B&M shifter. Easy to replace - tell the shop not to crank down on the stock shifter rod when re-installing so swapping it is easier. Swapping it out is super easy - just remove the center console pad & trim and thread it off, then screw on the shorter unit.Does that work in conjunction with the B&M? It goes in tomorrow, so Id likely have to add that on myself later if so.
