Reverse lights and blowing fuses
2001 GTS
Charlotte, NC
Noticed my back up lights weren't working the other day, neither was the rear defroster. So I changed the 10A fuse out for one I had close by..a 7.5A and it blew right when I put it in reverse. Now I put a 25A fuse in there and it didn't blow but I still dont have the reverse lights.
So I figure its the switch on the transmission...but what made the other fuses blow in the first place?
ViperJoe
Virginia
Did you d/c the reverse switch and put the smaller fuse back in and see what happens?
wesman
which fuse is it? My reverse lights don't work either.
AJT
Houston, TX , USA
I would not leave a 25A fuse in there, you will possibly melt some wires or start a fire.
KyViper
off to get a Beer
Had a similiar problem on my RT 10. If you want to PM me, I can send you over some wiring diagrams and suggestions on things to check. JPM.
ViperJoe
Virginia
Wes, the predominant "issue" with reverse lights is usually the reverse switch on the tranny
CROM
Fairfax, VA
Agreed. The reverse switch on the transmission is known to go out from time to time. My old GTS had this problem. As I recall the switch was 18 dollars and took me about 2 seconds to change once I had the car jacked up.
As far as the fuse. No idea. These cars seem to have very special exotic gremlins inhabiting them.
CROM
Fairfax, VA
Per the Wizard:
Switch #4626593 MSRP $28.75 [less 20% VCA]
Here's a good chance to support a vendor/board supporter...the best damned one in existence!
Tator's Dodge: 914-763-3136 :usa: :usa: :2tu:
2001 GTS
Charlotte, NC
Per the Wizard:
He's the first one I'll call anyway.
I'll change the switch out when I get a chance, and I took the fuse out for the time being.
Thanks guys
Slntnoze82
