Roe on higher compression motor?
HLN A55
Austin, TX
I built the bottom end of my motor a few years ago and am now looking for some more power. If I recall correctly, the motor is at 10.5:1 compression now-would I be asking for trouble by sticking a roe on it?
Ricketts
Fayetteville NC
Yes you are asking for trouble, only remotely safe roe way possible would be low boost 6 lbs, with water **** injection and a PERFECT tune. I still wouldn't recommend it though. Only choice I'd recommend on the engine would be nitrous, but I've never been a nitrous fan myself.
plumcrazy
ALL OVER
thats a bit high for boost. it CAN be done but........ you the rest. like said above, with a dead on tune and no room for error.
a call to greg good would help. who built the engine ? call them ?
H
HLN A55
Austin, TX
ART built it-I'm going to call them tomorrow to discuss.
I was thinking that I'd be pushing it a bit much . . .
Sneaky Pete
If you run a healthy shot of **** injection I think you'd be okay assuming the tuning was done well. Adding a decent octane booster or some race gas would be a really good idea if you go this route.
99 R/T 10
Enterprise, AL USA
You can take the heads off and open up the chamber to lower the compression. Call Greg Good for the options on this.
Russ M
LA, California
A good tuner and an AEM, or something like it can get you there. There are plenty of cars with 12:1 compression running around with forced induction. Or like some others have suggested a healthy amount of **** injection would work very well also.
countourcafe
