Roe Racing clutch pedal mod . kit
JKVIPER
Millstone Township, New Jersey
These were my comments when I installed the kit last year:
I'm 6'2" and in search of more leg room in the GTS.
I just installed a Roe Racing "Clutch Modification Kit". It lowered the clutch pedal level with the lowest setting of the brake pedal.
The kit was easy to install although the pin clips holding the bracket to the clutch pedal were very difficult to remove. If the directions had a drawing of the clip and how to release it, that would have helped. I eventually figured out how to release the clips and the rest of the installation was very easy. It took about an hour to install.
If you are looking for more leg room, I highly recommend this modification.
One other person recommended taking the driver seat out which would make it easier to get access to the clutch pedal assembly and clips.
Good luck
Hisserman
Waterford, MI
I've got it and it works fine. Dodge placed the clutch and brake pedals at different heights so that a driver could tell them apart in the tight footwell. Of course after you've become familiar with the setup it seems combersome for long legged drivers.
Just keep in mind that it's really tight in that footwell when you do the install. You may want to take the seat out to have more room (easy, just 4 bolts).
