seat belt and TPMS chimes
Longdaddy
is there a way to at least turn the sound off? pretty annoying in the paddock/pits
redtanrt10
Dana Point CA
I think there is a way to get the seat belt to stop, look in the owners manual, but you need to do the sequence every time before your fire the ignition. I just clip the belt before I get in, loop it behind the seat back. Doesn't get in the way with my 6 points in the stock seat. TPMS only chimes once or twice each time you turn the ignition, don't know how to make that go away (without adding sensors).
ViperGTS
in the Gen-4 I turned it OFF by doing the required sequence...look into the manual. Like engaging and releasing the seat belt several times together with working the ignition key.:D
