carl B
Fitted a Roe performance PCM today and no idle hang today!!??
Carl
Carl
Let the PCM learn for a few drive cycles before you declare the problem fixed.
btw, it's not software related. I think it'll come back once the car relearns the parameters with the new PCM.. but I hope for your sake it works!!Fitted a Roe performance PCM today and no idle hang today!!??
Carl
According to Mr. Horton (and I believe him), the butterfly plates allow air past even when closed all the way. He even suggested that if I had the throttle bodies off, I should hold them up to the light and could probably see if one is a bit more open than the other when they are supposedly "closed," but maybe a better description would be how well the round butterfly plate fills up the round throttle body channel. Given a little bit of "leak," then the IAC can open and close to finely adjust the amount of idle air. Just repeating what I heard.phoenixGTS hi i thought there was no air going past the throttle plates at idle.?? ie plates closed.the only air going into the motor coming from the iac motor?if air is going over the plates at idle could i connect a vacuum gauge to the two small ports on the manifold just behind the throttle bodies,and then adjust the plates????. i don`t think anyone in the uk has a drb tool.but i bet they got hang.ps i am new please forgive me if i am being a t*t.
lets get this beat.looking forward to your test results
DAVE.UK
