Seem to have small coolant leak - will a
tristan rizzi
Pensacola, Fla, U.S.A.
I would NOT use any kind of radiator sealant. On all the cars I have worked on all it did was gum up the thermostate and other critical areas of the coolant loop. I would invest the time into finding out where the leak is (ie head gaskets) and fix it properly once. Trust me your wallet, and car will thank you in the long run
Tristan
Ron
Indianapolis
<FONT face="Comic Sans MS">Do a search on coolant leaks. You will find you answer there.
You might want to check you warranty status before the search. It could be painful otherwise.....</FONT f>
countourcafe
