got one
Tried searching, but didn't find anything. How do I remove my side markers? Thanks!
Usually a 4" hole saw. Start with the hood right above where the light is. Then another hole in the fascia, a few inches below the markers. Once you get the holes done, take a 16" giant pair of channellocks and twist and pull until the light breaks free of the fascia. Don't worry about the broken plastic and torn wires. You'll have easy access to work through the new access holes you drilled.
*helpful tip* Tape off the headlights like at a track day. The shavings from the hole saw going through the hood can scratch them, making more work later.
You're welcome![]()
