SVS Turbo
SVS has put together a package where owners of SRT-10's or SRT Coupes would be able to lose over 100 lbs of rotating weight from changing out the stock wheels, tires, and rotors for street driving.
For those of you that don't want to change anything in your engine bay then this is the ultimate package for adding value and higher performance to your Viper.
The wheels are an exact replacement in size and offsets (19x13 & 18x10) in comparison to the stock wheels on both models. They’re the highest quality 1 piece forged magnesium wheels available in the world! There are no compromises in the building of these wheels for integrity, strength and style for the street or track.
Stock Wheels vs. SVS 1 piece (5 spoke) forged magnesium
SRT-10, SRT Coupe stock wheels/tires Michelin Pilot Sport run flat:
Front 18x10 = 60 lbs. ea.
Rear 19x13 = 73 lbs. ea.
SVS 1 piece forged magnesium 5 spoke wheels and same Michelin Pilot Sport:
Front 18x10 = 48 lbs. ea
Rear 19x13 = 59 lbs. ea.
Weight loss by changing wheels and using same run flat tires = 52 lbs
Stock front and rear: 266 lbs.
SVS front and rear: 214 lbs.
By changing to a new set of Michelin Pilot Sport NON run flat (zero pressure) tires you’ll lose another 3 lbs per tire:
Weight loss by changing to a zero pressure Michelin Pilot Sport = 12 lbs
By changing out the stock rotors and replacing with Brembo 2 piece race rotors you’ll lose another 10 lbs. off each wheel.
Weight loss by removing stock rotors and adding Brembo race rotors = 40lbs
Total rotating weight loss wheels, tires and rotors = 104 lbs.
When adding the SVS rotating weight loss package to your Viper you’ll notice that acceleration, deceleration and handling will be greatly improved. When losing over 100 lbs. of rotating weight your drive train will experience less stress under load. Rotating weight loss equals a significant amount of static weight loss and can have a substantial increase in performance.
This is the ultimate weight loss package for your SRT or SRT Coupe.
1 piece forged (5 spoke) magnesium wheels (18x10 & 19x13) $ 10,300
Michelin Pilot Sport Zero pressure tires (same sizes as stock) $ 1,600
Brembo 2 piece race rotors $ 2,500
$ 14,400
The manufacturer builds wheels for F-1, exotics and are the OEM supplier of wheels for Chrysler products.
$ 14,400
