Gen3 RSI Twin Turbo Install Questions Thread
V10Sidepipes
Virginia
Good evening all,
I am installing a RSI TT kit on my Gen 3 and wanted to pick some collective brains on some of the install points.
Question 1: What is everyone doing to relocate the PS cooler as it and the intercooler want to share the same space? I have an idea but with as many TT vipers with front mounts it should be a pretty solved issue by now but I can’t find any pics.
Badsnek
Pennsylvania
Good evening all,
Props for giving it a go yourself. Did you try calling RSI? I would check there first.
V10Sidepipes
Virginia
Yeah I could call up Paul or Will. I’ve spoken with them a ton over the years but also wanted to see if anyone was doing anything differently vs how these kits were originally designed years ago.
proedge
The power steering cooler goes onto the support bar below. Pic attached. You have to disconnect the lines and flip it around and then reconnect them. They are just on quick connect clips. I just took apart my RSI twin turbo Gen 3 convertible and moved everything to a Gen 3 coupe, so I know how everything goes. You also need to make a couple of tabs for the hood release as it needs to be relocated inside the impact bar
