SRTC - door/window sensor system and low tire indicator
Bobpantax
Miami
If you have a new coupe, have you experienced problems with the low tire indicator system and with the mechanism that lowers and raises the window a bit when you open and close the door of your coupe? It is my understanding, from two different dealerships that these two isssues are fairly common.
Viperfreak2
Duncan, SC USA
When I drive my car in the morning, I sometimes get a lo tire warning. When the tires build a little heat it goes off. I've always had the trick window problem....still do. I know, not a coupe. Same systems on all SRT Vipers.
Beamer75
