Stainless Side Sill Plates
INSOMNIAC
Europe
Looking for Stainless Steel Side Sill plates for my SRT-10.
Who has them?
How much?
Thanks.
mark777
Las Vegas, Nevada
FYI...
Just recently had them installed. While they look good they basically reverse the effects of wrapping insulation around the side exhaust since they are very good conductors of heat... In other words, OUCH!
My two cents.
Mark
I
INSOMNIAC
Europe
FYI...
My two cents.
Mark
PM Sent.
I
INSOMNIAC
Europe
FYI, if you buy from http://www.zero-altitude-flight.com/index.html make sure you have them made with the side sill mounting screw holes punched in them so if you need to remove your side sills you will not have to rip off the side sill plate which is glued down with double sided foam.
I bought mine from somewhere else Robbie and it comes with the mounting holes.
Thank you for the help and advice. :2tu: :2tu:
RayC
MI
Ditto on the mounting holes. I had to modify mine myself. I have not noticed any increase in side sill temp with them.
1997 GTS B/W
2004 White mamba
2006 VCA Coupe
Hiss
Kentucky
Mine had the mounting holes and I also did not notice increase in sill temp.
Nice mod.
SweetRed04
Iowa
FYI...
My two cents.
Mark
Stainless steel is a POOR conductor of heat compared to the factory aluminum side sill. Something else is going on....
