Are the size of the rods in the pre 01 different GTS different then the rods in a 01 GTS?
So when replacing a 01 piston with an pre 00 piston, I should change the rods also to pre 00 rods and not use the 01 rods with a pre 00 piston?
Also, besides cast vs forge, is the only size difference between an 01 piston and pre 00 piston are .002? Cast being 3.997 and forge being 3.995 (could someone verify please). So this means the cast are slightly larger the the forge because the forge expand?
