stripped side sill bolts
homesite
Hello,
Does anyone know what sizes bolt to use to replace the stripped out side sill bolts on the bottom of the side sills. I removed the cats on my srt and now 3 bolts will not tighten.
GR8_ASP
No but quite interested in details about the cat removal.
H
homesite
What size is the bolts that come from the factory?
Thanks!!!
GaryA
USA
Actually, I just noticed that you were talking about an SRT. I'm not sure what the factory screw size is. I believe they are #8 on the Gen 2s.
95Viper
Phoenix
From what I understand, they will keep stripping. I used high temp, low strength loctite putting mine back on and barely torqued them.
There is a writeup in the illustrated section on replacing them with a type of rivit and you use a stainless screw, it won't ever strip.
stevnme
