Sueaking!!! Where????
2001 GTS
Charlotte, NC
For the past 6 months or so, when I take the car out for the first time of the day/week. There is a squeak...squeak...squeak that speeds up as the car speeds up, its coming from the drivetrain or something that revolves when the car moves. Its not the engine, not a belt, and not the brakes. It does it non-stop, doesn't matter if turning one way or another or on the brakes.
It does it at pretty much all speeds until there is heat in the drivetrain, then it goes away. But it is pretty noticable from inside the car...and has to be audible from the outside too.
I called Chuck Tator last week and he advised I torque down all the wheel nuts and check the driveshaft and go from there. Once I get the car on a lift I'll look at the driveshaft.
This happen to anyone else?
Car has below mods and 50K miles.
Thanks,
Steve
mit
Austin, TX USA
I have creaking on mine that's really bad when I back the car out in the morning. My tech thinks it's the sway bar bushings. He says that's a common problem. I'll let you know next week. I drop it off on Monday.
2001 GTS
Charlotte, NC
I had a U-joint a month ago go dry because of movement inside the cap..but it was making a knocking sound.
I'll check the driveshaft when I get a chance.
