Sway Bar Part Numbers???
pokeyl
I am looking for Gen 3 and Gen 4 ACR part numbers, Also Gen 5 ACR/TA..
If anyone has a data on the spring rate that would be good also.
SA HEAT
Bulverde, Texas
2008 ACR:
Front: 514 lb/in
Rear: 1085 lb/in
Front Anti-roll Bar: 27mm Solid
Rear Anti-roll Bar: 27mm Solid
Try 5181444AA (front) and 51814438AA (rear)
pokeyl
pokeyl
Has anyone mixed bars? hollow front and solid rear? or the other way???
I know Dodge did a lot of work getting them to match.
At Autocross I want the front turn-on, as much as I can get. suspension 101 more rear plans the front. flip side more over-steer, tail happy!!!
Old School
North Alabama
The reason hollow sway bars are used is less weight, they are very close in stiffness to a same diameter solid bar.
monoman2345
