EA6BPilot
After jacking my GTS up to remove the rear wheels and install Tom Hayden's calipers, I noticed a small screw that was imbedded into the tread. Since I live pretty close to a small auto repair center, I loaded the tire into my truck and dropped it off to be plugged while I worked on the brakes. I came back after the job was done, paid for the service, and then installed the tire back on the car. I drove around for a day or so and noticed a very weird feeling in the rear end as I accelerated and braked (it felt like it was breaking loose slightly). I was paranoid that I didn't torque the lug nuts enough and that they were coming loose. This wasn't the case as I installed the wheels correctly. I did, however, decide to check the tire pressure. The repaired tire was showing 48 PSI cold!!!! I couldn't believe it! I didn't tell the garage that I wanted 30 PSI (my fault...I know), but I don't see why they'd fill it to 48 PSI!
I haven't said anything to them since I am to blame for not supervising, but I figured I'd let everyone here know to beware the next time they take their tires in to a non-Viper tech. Every other time I've had tire work done, I've stood next to the guys and watched what they did (a little anal and paranoid, I admit).
Ok.....I've vented a little now. Anyone have this happen to them?
