Torque Specs?
Vipermed 97.01
Tampa Fl. USA
Frank,1ST torque all bolts to 1Nm(10inch lbs)then go to 11Nm(95inch lbs)DO NOT CONFUSE INCH LBS WITH FT/LBS!you are going to start in the middle, 2 on each side at a time working youre way out, once you finish #5and 6 do an X pattern till you finish,start on Drivers side,sounds confusing but its not,easier with diagram,but if you mix up a couple no disaster just make sure you start in the middle and work your way out. Make sure you post a picture when youre done...Merry Christmas.Scott
