Tr6060 install in a gen3
Green viper 1
I'm installing a tr6060 in my gen three and was wanting to ask anyone who has experience doing t,his if I can use my
Gen3 clutch or do I need to buy a clutch for a gen4
Cape Coral, FL
Have done it, no problem. You can keep the Gen-3 clutch. Rule is that you can use a Gen-3 or 4 type cltch with a TR6060, but you can only use a Gen-3 clutch with a T56. The splines cut on the shaft are considerably longer on the 6060, and can accomodate either.
G
Green viper 1
Thanks for the info also I have been reading and some people have said that you can use the yoke from a ram srt10 instead of purchasing a new drive shaft this correct
Nine Ball
Houston, TX
Just the 2010 model has the upgraded 5th gear ratio. And the very few 2013 prototype trans that a few of us bought. 2008-2009 TR6060 still have the weaksauce 5th gear overdrive.
countourcafe
