Motor City Mad Man
Does anyone have the specifics on this TSB 18-32-97? I had this happen to me once about a year ago where the RPM's dropped at about 5500 RPM's and almost shut off. I have a early 1996 GTS. The check engine light came on, I took it to the dealer and all they could tell me is that they thought my battery charge was low. Then I discovered this TSB that exactly described my problem recently. Does the fix just involve re-flashing the PCM or something? My subscription for ALLDATA expired about a month ago and I don't think it had this TSB in there. My vehicle is still under an extended Max Care warranty, will this be covered by an extended warranty? I also had the problem described in TSB 18-15-97 intermittent hesitation between 4-5,000 RPM's, but I have the details for this.
