Viper up in flames
newredrt10
Administrator
Warren, OH
Was at Viper days in Beaverfalls Pa. today. As I left the track there was a burn spot on the road with fiberglass all around it. The people who where standing around it said it was a Viper. It looks like it was a total burn down. Does anyone know who it was and if any body was hurt.
Leslie
Indiana
no way!
I was there too, left about 530pm, just got home (in black Z06)
Wojo
Burlington, Ontario
Yes, it was my car. I got out before it was totally engulfed in flames. I am still in chock. I came up from Ontario to pick the car up. I was lucky to have come up with a good friend of mine who drove me there and back.
ArlyDude
PA
Well for just having your viper go ****, you don't seem to mad. :eek:
Wojo
Burlington, Ontario
I am in shock!!! Not the power steering cap. I was told that it may have been the fuel filter. The fire started at the rear. I have not had the car since July 1st, it was being repaired following a catalytic converter fire to the left side. It was suppose to be running fine. I took it out for a test drive and never made it back!!!
Warfang
California, East Bay
He was so mad he couldn't spell "shock". give the guy some slack. ;)
...so sorry about your loss, Wojo
Cal Cobra
Brentwood, CA
Hey Wojo sorry to hear that, it's a real bummer :(
Just curious, but did the car have the factory heat shields on?
Cal
Gerald Levin
Indianapolis, IN
Why power steering cap? The car can catch fire because of that?
JiPi, You need to do a search on power steering caps as they tend to loosen, and when they do, your car can end up in flames. There is an improvement made by Hipo Engineering (?) that will solve this problem and for $20-30 should be mandatory on every viper. A couple dealers handle this part but not sure which ones. Check it out.
Edit:
Just found the link with more info:
http://www.hipoengineering.com/PowerSteeringTube.asp
Wojo
Burlington, Ontario
Could not sleep at all last night! I am totally devestated!
Cal, if you mean the heat shielding under the side sills, I believe that it was stock(new).
I had the power steering vent installed and a power steering cooler.
Leslie
Indiana
Wojo, I am SO SORRY for your loss!
You must be PAST devastation
I hope you get a viper replacement-SOON
Inferno
Edit:
If that is true, where the hell is the factory re-call?
Cal Cobra
Brentwood, CA
Hey Casey,
I was thinking about the heat shields around the headers.
I hope the insurance co doesn't give you a hassel, and you're able to pick up another Viper you like.
Cal
Wojo
Burlington, Ontario
[image]http://givemealook.com/ipw-web/gallery/album43/Picture_098[/image]
That is a picture of what my GTS looked like.
Thanks for all of your concerns.
Chris
viper spray
Austin, Texas , USA
He said , " The fire started at the rear " , so I am thinking it may have been the , "running a bit rich - backfire flame lights up the rear facia" issue. Or a fuel leak , but not the power steering cap or the header heat shields.
countourcafe
