VR-12
viperman4125
North Port, Fl.
Has anyone use the product VR-12 in there cooling system, it's an attative. Helps cool by 30%. Does it work? Do you recommend it ?
Go to VR-12.com,
ViperGTS
no wonder all car manufacturers use it like hell :lmao:
kenphjr
I believe Royal Purple and Red Line also have similar products that are supposed to drop the coolant temps-don't know if they work or not
Bugman Jeff
Wisconsin
I'd stick with the tried and true Water Wetter. I've never heard of VR-12, but water wetter actually does work. It works by lowering the surface tension of the water in the cooling system. It effectively increases the surface area of the water contacting the metal parts, giving you better heat transfer. It's most effective on cars that are on the verge of boiling, the benefits won't be as noticeable on a system working within "normal" conditions. Since Vipers typically run so hot anyway, it wouldn't hurt to add some.
ctrengine
