What's the difference between regular and Viper T56?
Tom F&L GoR
Wappingers Falls
What\'s the difference between regular and Viper T56?
I need some internal parts (anybody have a main shaft gear set in good shape?) and will need to know what I can and can't use from the "other" brands and their versions of the T56? Thanks.
RS27J9A
Re: What\'s the difference between regular and Viper T56?
do you mean "regular" in terms of a T56 out of a camaro SS or WS6 trans-am? If so I am almost sure they are 100% the same as the ratios are all the same.
Makara
Hollywood, CA
The price. Am I right, or am I right?
Mike Brunton
N. Andover, MA
I seem to remember this thread coming up a looong time ago and the real REAL answer was that they are not infact the same. It may have been some very minor differences... I want to say maybe something in the synchros were different - maybe not.
Actually, the thing I DO remember is that David ***** was the one who investigated this and he would know the answer. I know he not 'round these parts no 'mo but he is on the .com site and may have the answer you're looking for.
pauls
Akron, Oh USA
David's comments at the time where" GM package had a different ratio and were not as strong as the Viper package" His experience was converting some Vipers to GM ratios for road racing.
Chuck 98 RT/10
tampa, fl USA
I heard the Viper Tranny is beefed up to handle the 500 ft lbs of torque.
Bill Pemberton Woodhouse
Blair,Nebraska,USA
Non-Technical answer from our Viper Tech (Rick Maxwell ). I asked it to be a generalized view since the last thing I want to get into is a transmission analysis with my limited knowledge.
Main shaft is different
Output shaft is different - shorter he believes
Gear ratio different
and, though not sure, he thought the diff. spline was different.
Hope this helps a little.
Bad_Byte
Corpus Christi Tx
In my past explorations I researched a little and found their web site to be at least a good starting point.
Click Here > Tremec
There are many versions with slight HP/Torque/GVW/GVC variations to each version as well as slight variations in the gear ratios.
Anthony - 98 GTS
Houston, Texas
Tom,
I have a complete T56 Viper tranny at my house. A couple of gears were bad so I just puchased another complete T56 for my GTS.
I assume the main shaft gear is the largest gear?? I could take some pics of what I have and send them to you. I also have a Factory shipping crate for a T56 if anyone is interested.
T
Tom F&L GoR
Wappingers Falls
Thanks for all the hints. Anthony, I'd love to talk to you about your "parts" and have sent you email.
For those that helped, a little something in return - the repair manual. It's better than the Dodge service manual.
T56 repair manual
countourcafe
