When to replace front O2 sensors
Great Falls, Montana USA
My 97 GTS now has over 50,000 miles on the clock. I have two questions:
(1)Is there a prescribed mileage to change out O2 sensors with new ones.
(2)My front (up stream) sensors have extra long wires (a non stock item supplied by a former engine builder who shall remain nameless). Anyone got a clue where these little gems can be found? Thanks in advance....(JD).
Larry Macedo
Sanford, FL
Jim,
At the time, I was purchasing those lengthened O2's straight from NGK Japan to my dimensions. You will most likely need to lengthen the harness side of the connector now if your planning to replace the H>M>S O2's. I believe it's prescribed they are replaced @ 60K.
Mike Adams
guelph, Ontario, Canada
It is easier and cheaper to get a universal O2 sensor and replace it. They come with connectors and everything. Just cut the [******] O2 sensor and splice these in. They heat up quicker and cost next to nothing. I use Blue Streak part number SG300 or for factory plugs for front 02 I use Blue streak SG229
You can get any make of Universal 4 wire 02 sensor though
