Who is running 305s on the front?
Wojo
Burlington, Ontario
Those who are running 305s on the front, what size of rim do you have? What is the widest tire you can put on a stock 18" rim (2000 GTS)? Thanks.
Viper X
305's fit nicely on the front of my 2001 GTS.
I have used 11 inch SSR's and 11 inch Forgelines. Tires vary from 305 x 30 x 18 Hoosiers to 305 x 30 x 18 Kumho Ecsta V-700s to 305 x 35 x 18 Toyo RA-1's.
As you can tell by the aspect ratio, the Toyos are a bit taller than the others, so they're not perfectly interchangeable without some adjustment.
Dan
Ar Tee Ten
