I understand that it would be more typical to have the passenger's side lock up first, since the weight would be more to the left. However, in my case this is not happening. I can lock up the driver's side tire very easily at fairly low speeds - less than 50 mph. In addition, there seems to be more heat on that side of the car - the brake caliper lettering is noticably more yellow than on the passenger side, much of the caliper finish is scoured off from brake dust, and there is some probably unrelated engine heat issues on the driver side. So, would it be possible to have an alignment shop corner weigh the car, or get some spring settings that would possibly isolate this problem?
A
