adg44
So, as I mentioned before, I am having some issues with my drivers side window. It makes a 'popping' sound when at the extreme bottom of the window travel. If you don't use the auto down and you stop the window before it hits bottom, it doesn't make any noise. That is what I've been doing for the time being until I get it fixed.
Furthremore, on the way up, this happens:
Also, when I washed the car this weekend, I noticed some water leaking through from the top of the window. It seems that the window angle needs to be adjusted and hopefully this will stop the problem.
So my question - is this manually adusted, or is it computer controlled? I am debating whether to tackle this myself or to take it into the dealer and have them adjust it.
Thanks,
- Anthony
Thanks,
- Anthony
