wire routing question
BruceW
San Diego
I need to run two small gauge wires from the trunk (I have an RT/10) into the passenger compartment. What is the easiest way to do this?
TIA
Bruce
Viper Wizard
South Salem, NY USA
Hi Bruce,
In your trunk, upper right hand side, forward, you'll see a bundle of wires. You could follow that routing, or you could route you wires toward the center after going through the hole and then follow the center console. You'll have to remove the panel from behind the seats to do this. Hope this helps?
plumcrazy
ALL OVER
chuck is right. i did it last week with my xm antenna wire and it went thru easy along the console. all ya need is a phillips head screwdriver.
