Zinc slotted and drilled rotors with ceramic brake pads
St.Char
Westfield, Indiana
(Zinc plated that is)..... Anyone try these? Are they decent?
Some that have used the drilled rotors had them crack under extreme heat (Tracking their car). If you are mainly street use, this will be a great set-up! Be careful when using wheel cleaners on the rotors, as most of the cleaners are acid based and will etch the rotor face. Good luck.
N
Nitro187
Oakville, Ontario
I just finished tracking at a Viper event, and my pads fell apart... obviously time for some new ones. ;) They were fine before hand... but I guess the amount of laps I did was too much... so I figured I would get some new ones... seems how it may be a while before the next track event, I figured these would look cool... I won't be tracking anytime soon, so these should be fine then. Thanks!
No members online now.
wesleyCrowbar
