05 viper locking problem
lexer05
I have a 05 just wandering if anybody has ever had problem locking or unlocking the doors.I will lock the doors,and the doors will lock then when i come back it wont unlock unless you push the door handle down.But if you lock it it works again,anybody heard of that please help, thanks
Roadrunner
It sounds like the car is in "factory storage mode"... which is enabled by the IOD fuse being in the SHIP position. The IOD fuse is the one with the little black plastic cage around it. The storage mode forces the BCM into sleep mode, which requires a door handle push to wake up in that case.
But if that is the case, you'd also have no radio once in the car I think.
Low battery will cause the same sleep to ensue.
BlknBlu
Omaha, NE
I had a similar issue when the battery died on my 08. I went to use the key in the lock and the key would not turn to unlock the door. any help?
Bruce
Omaha NE.
Bruce
Jump box on post under the hood and it will open giving you access. You will need to recharge battery and may even get CEL that will be cleared or your dealer can.
BlknBlu
Omaha, NE
That is the ticket, I did get in eventually and got it started but did throw a code. You nailed it.
thanks
Bruce
ulllose
Brunswick, Ohio
thanks
Bruce
you have to push on the top of the door pretty hard while turning the key. If you don't push on the door at the same time the key will NOT turn. Push right below the door release.
BlknBlu
Omaha, NE
There is a reason I come to this site daily. Great info even on the smallest items.
Bruce
ulllose
Brunswick, Ohio
Bruce
Just to make myself clear......you need to push toward the drivers seat not down toward the ground. You can sometimes use your right shoulder while looking toward the front on the car and turning the key in one motion......lol for real no joking around!!
Drock187
