1/2"-20 extended length female threaded lug guide tools
Fred@ReverseLogic
Philadelphia
Many European car owners use male threaded lug guide tools to facilitate the installation of wheels on their cars that use lug bolts to secure the wheels to the hubs. A single lug guide tool in conjunction with the hub collar will align the holes in the wheel with the threaded holes in the hub. Most auto enthusiasts would never consider using a lug guide tool on a car with wheel studs since the studs alone normally are adequate to guide the wheel into place.
Reverse Logic introduced female threaded lug guide tools in 2014. Initially the tools were the same length as the male threaded tools for European cars. Our Corvette customers enthusiastically embraced the female threaded tools which helped them install wheels over big brakes with minimal clearance between the wheel barrels and calipers. Reverse Logic now offers the female threaded tools in several thread sizes and lengths.
The tools for Vipers are 250mm long and have a 1/2"-20 thread. The longer tools are required for wide rear Viper wheels. A minimum of three tools is recommended to spread the weight of the wheel and tire over more studs. Using the lug guide tools minimizes the risk of banging the wheel barrels against the rotors and calipers as the wheels are positioned against the hub. Once the first three lug nuts are installed, the lug guide tools can be removed and the remaining three lug nuts can be installed.
http://www.reverselogic.us/shop.htm...d-Lug-Guide-Tools/p/65729054/category=4643105
naimsito
