1999 RT 10 Maintenance questions
AV108U
West Flamborough,Ontario,Canada
Ok, I've gone through some older threads about maintenance and just have some questions to those who have been through this already. When my car arrives what should I be looking for and what should I do first ? I would rather get some input from owners other than mechanics if you know what I mean..... Thx :dunno:
eucharistos
Houston
how many miles on the car :dunno:
maint records up to date :dunno:
basics: check tires - wear and age,
fluids, air filters, bulbs.....just like any other car to begin with
congrats
:drive:
Great car!!
I would check maintenance/replacement records first.
Then check tire for date codes, condition, and adjust pressures...betting that you'll need new tires.
Check all fluid levels and correct as necessary. Plan on changing ALL fluids unless you can prove that they are all up to date...and, don't forget the coolant overflow bottle in the right front fascia. Might change "radiator cap" on the pressure bottle to be safe.
Unless the battery is brand new, would get a new one...cleaning/prepping/painting tray as necessary.
Ask for help for specific problems here when ever you need it.
Enjoy your Snake...and, drive it carefully!!!
Yes to the key fob. Excellent point on the battery changes for the fob (be SURE you have 2 sets of fobs and keys!!!).
FastZilla
San Antonio, TX
Fob is the only way to turn the alarm off when you set it off...which you will, numerous times (popping the hood with the alarm armed is the one that gets me).
A
AV108U
Apparently the tires have 5000 miles on it and the service records are coming. I've read stuff on the overflow bottle. What exactly should be done to that ?
I know about the fluids but any other weird things I should replace or check ?
Thx
Asp Man
Kelowna B.C., WEStern Canada
On the o/f bottle, you've just got to make sure that the facia bolt (from underneath) is not touching the bottom of the bottle, some do, some don't. If it does, it can wear a hole in it over time, the results are predictable. Other than that, keep it at the proper level, though it is a bit of a pain to fill.
Check the battery, age and condition. As it's hidden it tends to get neglected. If it's leaky, it wil corrode the tray and batt. temp sensor, wiring, etc. in the area.
A bolt check is a good basic maint. item, too.
Welcome aboard and good luck with the new toy!
FastZilla
San Antonio, TX
Thx
Do a search - Dave666 has posted some really detailed (with photos) "how to".
To fill the overflow bottle:
- Turn wheel all the way left
- Pull out 3-4" rubber plug in outside bottom of the fender liner on the passenger side
- Shine flashlight in on bottle
- Look at slit inboard of plug removed and view water level.
- There is a high/low mark on the fender at the slit
- pull rubber hose off by radiator cap
- insert small funnel
- dump in antifreeze until level is at top mark of slit (about 1/2 down from top of slit
- put hose back on
- put plug back in
- Straighten wheel back out (optional)
- search for Dave's post - the pictures he takes are worth it!
Date codes on tires mean more than "miles" or "tread". Manufacturer usually recommends NOT using tires older than 6 years.
A UV light will help you see air/fluid level in the overflow bottle.
