2004 console lighter lid stuck closed
sssikvipe
Greetings everyone. i am hoping there is a simple way to get it opened, is it a fuse.....or an uncooperative mechanical spring that can only be reached by removing the console. thank you
georgethedog
Near Peoria, IL
Removing the console is not hard at all. Maybe I would have an idea but my car is up in the air on a lift for the winter. I would think you could remover the bezels...
sssikvipe
lol, yes steve, it took 7 yrs without a cigar to figure that out.
ROCKET62
Has Left the Room!
Phoenix, AZ bye-bye IOWA
To get at the lighter assembly - simply pry upon the bezel (there are 4 press-in tabs, one at each corner) which should give you enough access to see if anything is binding on the back of the lighter assembly. If you need more access, to remove the entire bezel - you remove the shift knob, undo the electrical connections for the windows, and then slide the bezel over the parking brake handle.
Off topic I know - but bluesrt - do you ever post anything constructive - do you even own a Viper - rant over.....
take a big hammer to it
01sapphirebob
"OIHO"
It can be removed. It would be a mechanical piece that is causing the problem. You have to remove the chrome piece from around the shifter and then get a flathead screwdriver and VERY GENTLY pry up the bezel. Start closer to the center console between the seats.
bluesrt
yes i do everyday, read some of my posts, go have a drink or a smoke and get that but otta your but.
sssikvipe
thank you all. got it open, used a thin exacto blade on drivers side and "tripped" something to get it open, closed it and then stuff again...going to take apart as suggested to see why
oldvenom
