Its good to locktite the bolt and behind the washer as well.
Torqued it down today, with some licorice. Someone was sleeping when they put this car together, that's all I'm gonna say. Quality control was no where to be seen.
This is a known issue in some of the '03's and '04's (built prior to 02/04). The reason why I asked you to check the build date. A TSB was issued against this problem so whomever owned your car previously failed to address the TSB or maybe something else is going on. The service records should indicate if the TSB was previously addressed.
ALL Vipers EXCEPT the 2004 and maybe some EARLY 2005's have a "big dog" of a crankdamper bolt...that should be checked periodically, especially if running high HP. For whatever reason, 2004's and MAYBE some early 2005's have a "teeny weeney" sized crankdamper bolt, which was torqued to MUCH lower specs...and, in my opinion (as well as that of several of the better known Viper Techs' opinion) was prone to getting loose with potentially disasterous results. There IS a fix...but I personally worry about the loose ones that were "owner-fixed" as well due to their potential propensity to "rear the ugly head" of delayed failure down the road as it is hard to estimate likelihood of damage from the harmonics that could have been unleashed. For bolt specifics, see my post below:
"Actually, the search key reveals a lot:
From this thread in which Dan lays out the problem: " Re: My Crankshaft Damper Bolt was falling out. "
http://vca2.viperclub.org/forums/sho...mp;o=&vc=1
The Text in part that I posted says: "Earlier in this thread I posted:
" You decide..."the year MAY matter"...
03 Manual says "250 ft-lbs"
04 Manual says "130 ft-lbs"
05 Manual says "130 ft-lbs"
Now (thanks to Tim in Parts at Indy's Champion Dodge) here more info taken straight from the Dodge computer (with a little extra effort).
Crankshaft Damper Bolts:
2003 part number 6036207AA size 0.75x16x2.250 (inches)
2004 part number 6506340AA size M14x1.5x102.0 (metric)
2005 part number 6506340AA size M14x1.5x102.0 (metric)
2005 part number 6036207AA size 0.75x16x2.250 (inches)
2006 part number 6036207AA size 0.75x16x2.250 (inches)
LOOKS TO ME AS THOUGH THERE WAS A RUNNING CHANGE SOMETIME IN THE 2005 MODEL YEAR.
By the way, I have ordered one
Actually, it was all 04s, and early 05s I believe. According to (I think) one of Steve-Indy's old threads the 2003, late 2005, and 2006 bolts are the same part number, while the 04s and early 05s are the problem children. Someone else chime in and correct me if I'm wrong. Here's the quote I found searching (look especially at the part numbers; 03, later 05 and 06 are the same):
04's up to the 01/31/04 build date with a "Z" or "H" in the 8th VIN position . Only covered cars up to this date per notification no. D19 (service action #04-006). Did not include any '05's or '06's.
I am sure the small bolt came on all 2004's...but I really cannot say anything about the EARLY 2005's, as I only know what was speculated upon by trusted Viper Techs and the listing in the 2005 parts manual at that time.
That said, when it comes down to one individual Viper...just reach down and size the hex-head on the crank damper bolt YOURSELF...if it takes a 1 & 1/4 inch socket, it's the BIG, STRONG bolt...if it takes 13/16 inch six-sided socket it's the "teenie ******"...torque as outlined above (250 ft-lbs if BIG and 130 ft-lbs if "teenie ******").
As I have stated before...MY worry is not how to re-torque the loose 2004's (or any other damper bolt)...but what damage was done while the damper bolt was loose??!!!!! Scary stuff when one looks at the damage that has been observed on the crankshaft in some cases !!
And, just for the record...we should ALL check these bolts regularly on ALL years of Vipers...which I was/am doing...and STILL, that sly fox Tom Sessions found one of our Vipers with a "somewhat under-torqued" damper bolt !!!
