2005 PCM pin layout
ViperGTS
A friend of mine has trouble with the lambda sensors and needs information about the PCM, pin layout and which pins have the signal from the O2-sensors?
Thx!
kickinasp
USA
Conncetor C1 Black/Black 32 Way
CAV
CIRCUIT
FUNCTION
K32 18DB/WT
IGNITION COIL NO. 4 DRIVER
F202 18PK/GY
FUSED IGNITION SWITCH OUTPUT (RUN-START)
K18 18DB/OR
IGNITION COIL NO. 3 DRIVER
K900 18DB/DG
SENSOR GROUND
K134 18DB/YL
IGNITION COIL NO. 5 DRIVER
K19 18DG/DB
IGNITION COIL NO. 1 DRIVER
K24 18BR/LB
CRANKSHAFT POSITION SENSOR SIGNAL
K17 18DB/TN
IGNITION COIL NO. 2 DRIVER
K39 18VT/LG
IDLE AIR CONTROL NO. 3 DRIVER
K60 18VT/DG
IDLE AIR CONTROL NO. 2 DRIVER
12
13
14
15
K21 18LG/DB
INTAKE AIR TEMPERATURE SENSOR SIGNAL
16
K2 18VT/OR
ENGINE COOLANT TEMPERATURE SENSOR SIGNAL
F855 18PK/YL
5V SUPPLY
18
K44 18DB/GY
CAMSHAFT POSITION SENSOR SIGNAL
19
K59 18BR/DG
IDLE AIR CONTROL NO. 4 DRIVER
20
K40 18BR/LG
IDLE AIR CONTROL NO. 1 DRIVER
21
22
A14 16RD/YL
FUSED B(+)
23
K22 18BR/OR
THROTTLE POSITION SENSOR SIGNAL
24
K41 18DB/LB
OXYGEN SENSOR 1/1 SIGNAL
25
K141 18TN/WT
OXYGEN SENSOR 1/2 SIGNAL
26
K43 18DB/LG
OXYGEN SENSOR 2/1 SIGNAL
27
K1 18VT/BR
MANIFOLD ABSOLUTE PRESSURE SENSOR SIGNAL
28
29
K243 18BR
OXYGEN SENSOR 2/2 SIGNAL
30
31
Z12 16BK/OR
GROUND
32
Z12 16BK/TN
GROUND
Connector C2 Black/White 32 Way
CAV
CIRCUIT
FUNCTION
K26 18BR/OR
FUEL INJECTOR NO. 7 DRIVER
K115 18BR
FUEL INJECTOR NO. 9 DRIVER
K11 18BR/YL
FUEL INJECTOR NO. 1 DRIVER
K13 18BR/DG
FUEL INJECTOR NO. 3 DRIVER
K38 18BR/OR
FUEL INJECTOR NO. 5 DRIVER
K20 18BR/GY
GENERATOR FIELD DRIVER
K58 18BR/VT
FUEL INJECTOR NO. 6 DRIVER
13
K28 18BR/LB
FUEL INJECTOR NO. 8 DRIVER
14
K116 18BR/LG
FUEL INJECTOR NO. 10 DRIVER
15
K12 18BR/DB
FUEL INJECTOR NO. 2 DRIVER
16
K14 18BR/TN
FUEL INJECTOR NO. 4 DRIVER
C240 18LB/TN
HYDRAULIC COOLING FAN CONTROL
18
19
C18 18LB/BR
A/C PRESSURE SIGNAL
20
21
K136 18LB/BK
REVERSE LOCK-OUT SOLENOID CONTROL
22
23
G6 18VT/GY
OIL PRESSURE SENSOR SIGNAL
24
25
26
27
G7 18VT/OR
VEHICLE SPEED SENSOR SIGNAL
28
29
G24 18VT/BR
OIL TEMPERATURE SENSOR SIGNAL
30
31
F888 18BR/PK
5V SUPPLY
32
Connector C3 Black/Gray 32 Way
CAV
CIRCUIT
FUNCTION
C13 18LB/OR
A/C CLUTCH RELAY CONTROL
K51 18BR/GY
AUTOMATIC SHUT DOWN RELAY CONTROL
K33 18DB/LG
SKIP SHIFT SOLENOID CONTROL
K42 18DB/YL
KNOCK SENSOR NO. 1 SIGNAL
K79 18BR/LB
OXYGEN SENSOR 1/1 HEATER CONTROL
K127 18BR/OR
OXYGEN SENSOR HEATER RELAY CONTROL
K106 18VT/YL
LEAK DETECTION PUMP SOLENOID CONTROL
K342 16BR/WT
AUTOMATIC SHUT DOWN RELAY OUTPUT
13
14
K107 18VT/WT
LEAK DETECTION PUMP SWITCH SENSE
15
K25 18DB/VT
BATTERY TEMPERATURE SENSOR SIGNAL
16
K80 18BR/TN
OXYGEN SENSOR 2/1 HEATER CONTROL
K90 18LB/TN
STARTER MOTOR RELAY CONTROL
18
K242 18BR/YL
KNOCK SENSOR NO. 2 SIGNAL
19
K31 18BR
FUEL PUMP RELAY CONTROL
20
K52 18DB/WT
EVAP/PURGE SOLENOID CONTROL
21
22
C20 18DB/OR
A/C SWITCH SENSE
23
24
K29 18WT
BRAKE LAMP SWITCH SENSE
25
K125 18BR/DG
GENERATOR SOURCE
26
27
D21 18WT/BR
SCI TRANSMIT
28
29
D20 18WT/LG
SCI RECEIVE
30
D25 18WT/VT
PCI BUS
31
32
majic26
