I have seen a couple places where people have been doing stroker kits..
What types of setups are people doing?
Who is doing the engine work?
THanks,
Joe
Very interesting post...
Not to get away from the original question.... Are the strykers worth it??
Will a blown car with stock crank and strykers really be better than a stroked one with strykers????
I have read that the strykers are the best for cooling reasons on a blown car... Is this really true... Or can Mr. Good really make your stock castings that good????
Thanks,
Joe
Yes Strykers work amazing, Are they worth it? That depends on you. No stock ported head will match them, and my car runs noticeably cooler with them. Castings are far thicker and more stable than stock.
Your second question is far too vague, and it really depends on your application and desires. Some desire N/A, while some like blown. My original answer to you was based on your desire to piece a motor together, not what is best.
I have heard nothing but great words about Greg Good, and he can probably port a set of stock castings to near Stryker power levels. It's just the simple fact that the Striker head is a much better design.
What are people doing with there fuel systems?
and can the cams be bought or ordered? or do you have to get a custom cam made??
Joe
Camfab - wish I could say the same thing regarding heat with my Strykers. I can get 4 or 5 hard laps on them before the water temps are at 250 degrees. Prior to the swap I would run 220-225 on hard laps. End of races I may reach as high as 235 if it was a hot June/July. Before they get super hot they do seem to make power though. Its a bummer right now though because the improved water jackets and design was a huge factor in my purchasing decision.
