A Call for a Metallurgist and/or Oil Analyst
Sweet Ride
Denver, CO
Hi all:
I recently sent out oil samples from my engine and transmission.
The engine oil came back showing a slightly high level of lead (67 PPM). What in the Viper engine contains lead or a lead coating?
The transmission came back showing elevated levels of silicon (55 PPM). What in the transmission would cause a high silicon level?
I was running Synthetic 10W30 in the engine and Syntorq 75W85 in the transmission. Other than the two stated issues, all other wear metals were in a "normal" range.
I can provide the .pdf files if needed. Any guidance would be appreciated.
Thank you!
Tom F&L GoR
Wappingers Falls
Lead in the oil usually is a sign of using leaded gasoline. Use any race or avgas lately?
Silicone is a generic way of saying "dust" from the air. In engine oil it means the air filter needs checking. In a transmission or differential the breather system doesn't often have a filter; maybe just a sponge in front of the breather tube?
Did you know that there is an official "test dust" used for oil filter efficiency testing? It comes from a desert out west. It is actually calibrated for size and distribution. And where are you located? ;)
If this is end-of-drain analysis, neither is particularly high. What were the levels last time?
Steve 00RT/10
Michigan
Hi all:
Silicon in the tranny or differential is not necessarily dust or dirt. It could be silicon sealer, in which case....not a big deal. Have them do a filter patch test on the sample if they still have it. This happened to me once.
Steve
Sweet Ride
Denver, CO
No leaded gas or avgas ever that I know of. I always fill up with 91 Octane unleaded.
I looked back at the test sheet and it specifically states: "Silicon Most Likely From Source Other Than Dirt" Do these transmissions have a breather sponge on them? :dunno:
"Test Dust"? That's funny. We don't have any of that around here...
This was the first test, so I will have to wait for my next oil change to get another decent sample.
Steve
Thanks for the tip but I believe they already tossed the sample. I believe this transmission was rebuilt once and I believe this is the first fluid change since the rebuild. I don't doubt that it could be some kind of sealer.
Thank you both for your responses!
