Could be a bunch of things. If you don't know much about a/c work you should find a good tech to have it checked it out. You need somebody to put gauges on it and see what's going on internally.
Couple things you can check: Is the a/c Compressor turning? Got bubbles in the sight glass? Are you sure the heater valve is closed all the way?
